ผู้เขียน หัวข้อ: Engine Error Code From 4D56  (อ่าน 10789 ครั้ง)
« เมื่อ: กันยายน 17, 2013, 12:49:26 pm »
FAIL-SAFE AND BACKUP FUNCTION
The control is carried out, which keeps the safety driving by the preset control logic when the diagnostic trouble code is output. The diagnostic trouble code having the fail-safe function is as follows.
List of fail-safe and backup function items
Code No.                                        Diagnosis item                                                       Control content during malfunction
P0016            Crank angle sensor/camshaft position sensor phase problem             -The engine is stopped (fuel injection and pump pressure feed are stopped).
P0072            No. 2 intake air temperature sensor circuit low input                       -No. 2 intake air temperature is controlled as 50°C.
        -Exhaust gas recirculation control is stopped (fully closed).
P0073            No. 2 intake air temperature sensor circuit high input                      -No. 2 intake air temperature is controlled as 50°C.
P0088            Common rail high pressure malfunction                                     -The throttle valve is shut (opening fixed).
P0089            Suction control valve stuck                                                   -Rail pressure is controlled in the range from 50 to 100 MPa.
        -Fuel injection is restricted (output restriction).
        -The open angle of the accelerator pedal is controlled.
P0093            Fuel leak problem        -The engine is stopped (fuel injection and pump pressure feed are stopped).
P0102             Air flow sensor circuit low input                                             -Exhaust gas recirculation control is stopped (fully closed).
        -Control is performed using the previous value.
P0103             Air flow sensor circuit high input                                            -Exhaust gas recirculation control is stopped (fully closed).
P0106            Manifold absolute pressure sensor range/performance problem          -Manifold absolute pressure is controlled as 100 kPa.
P0107            Manifold absolute pressure sensor circuit low input                         -Manifold absolute pressure is controlled as 100 kPa.
P0108           Manifold absolute pressure sensor circuit high input                         -Manifold absolute pressure is controlled as 100 kPa.
P0112            No. 1 intake air temperature sensor circuit low input                        -No. 1 intake air temperature is controlled as 50°C.
P0113            No. 1 intake air temperature sensor circuit high input                      -No. 1 intake air temperature is controlled as 50°C.
P0117            Engine coolant temperature sensor circuit low input                        -Engine coolant temperature is controlled as 80°C (-25°C at startup).
« ตอบ #1 เมื่อ: กันยายน 17, 2013, 12:52:00 pm »
P0118            Engine coolant temperature sensor circuit high input                       -Engine coolant temperature is controlled as 80°C (-25°C at startup).
P0122          Throttle position sensor circuit low input                                      -Power to the throttle valve control servo is interrupted.
P0123           Throttle position sensor circuit high input                                    -Power to the throttle valve control servo is interrupted.
P0182           Fuel temperature sensor circuit low input                                    -Fuel temperature is controlled as 45°C (-25°C at startup).
P0183            Fuel temperature sensor circuit high input                                  -Fuel temperature is controlled as 45°C (-25°C at startup).
P0191            Rail pressure sensor range/performance problem                         -Rail pressure is controlled in the range from 50 to 100 MPa.
        -The throttle valve is shut (opening fixed) Exhaust gas recirculation control is stopped (fully closed).
P0192            Rail pressure sensor circuit low input                                      -Rail pressure is controlled in the range from 50 to 100 MPa.
P0193            Rail pressure sensor circuit high input                                     -Rail pressure is controlled in the range from 50 to 100 MPa.
P0201            No. 1 injector circuit malfunction                                            -Exhaust gas recirculation control is stopped (fully closed).
P0202           No. 2 injector circuit malfunction                                            -Exhaust gas recirculation control is stopped (fully closed).
P0203           No. 3 injector circuit malfunction                                            -Exhaust gas recirculation control is stopped (fully closed).
P0204           No. 4 injector circuit malfunction                                           -Exhaust gas recirculation control is stopped (fully closed).
P0219            Engine overspeed condition                                                  -The throttle valve is shut (opening fixed).
P0234           Turbocharger overboost condition                                          -Fuel injection is restricted (output restriction).
P0335            Crank angle sensor system                                                 -The engine is stopped (fuel injection and pump pressure feed are stopped).
P0336            Crank angle sensor range/performance problem                  -The engine is stopped (fuel injection and pump pressure feed are stopped).
P0340            Camshaft position sensor system                                          -Rail pressure is controlled in the range from 50 to 100 MPa.
P0341             Camshaft position sensor range/performance problem                 -Rail pressure is controlled in the range from 50 to 100 MPa.
P0403            Exhaust gas recirculation valve (DC motor) malfunction                  -Exhaust gas recirculation control is stopped (fully closed).
« ตอบ #2 เมื่อ: กันยายน 17, 2013, 12:55:19 pm »
P0405           Exhaust gas recirculation valve position sensor circuit low input         -Exhaust gas recirculation control is stopped (fully closed).
P0406           Exhaust gas recirculation valve position sensor circuit high input        -Exhaust gas recirculation control is stopped (fully closed).
P0502           Vehicle speed sensor low input <4WD>                                               -None
                   Vehicle speed signal low input <2WD>                                                 -None
P0513              Immobilizer malfunction <Vehicles with immobilizer system>            -None
P0604            Random access memory (RAM) malfunction                                        -The engine is stopped (fuel injection and pump pressure feed are stopped).
P0605            Read only memory (FLASH ROM) malfunction                                   -Rail pressure is controlled in the range from 50 to 100 MPa.
P0606            Engine-ECU (main CPU) malfunction                                     -Rail pressure is controlled in the range from 50 to 100 MPa.
P0607            Engine-ECU (sub CPU) malfunction                                       -Rail pressure is controlled in the range from 50 to 100 MPa.
P0628            Suction control valve open                                                  -Rail pressure is controlled in the range from 50 to 100 MPa.
P0629            Suction control valve battery short                                     -Rail pressure is controlled in the range from 50 to 100 MPa.
P0630            Chassis number not programmed                                           -None
P0638            Throttle valve control servo stuck                                         -Power to the throttle valve control servo is interrupted.
P0642            Analog sensor reference voltage No. 1 too low                      -The accelerator pedal opening is controlled as 0 %.
        -Idle rotations are 1,300 r/min (both main and sub are faulty or have a characteristic error).
P0643            Analog sensor reference voltage No. 1 too high                     -The accelerator pedal opening is controlled as 0 %.
P0652            Analog sensor reference voltage No. 2 too low                      -The accelerator pedal opening is controlled as 0 %.
P0653            Analog sensor reference voltage No. 2 too high                    -The accelerator pedal opening is controlled as 0 %.
P1203            Capacitor insufficient charging                                             -Rail pressure is controlled in the range from 50 to 100 MPa.
P1204            Capacitor excessive charging                                              -The engine is stopped (fuel injection and pump pressure feed are stopped).
« ตอบ #3 เมื่อ: กันยายน 17, 2013, 01:03:43 pm »
P1272            Pressure limiter malfunction                                     -None
P1273           Supply pump insufficient flow                                    -Rail pressure is controlled in the range from 50 to 60 MPa.
        -A/C is cut <Except the driving condition that the fuel pressure exceeds the seizure resistance>.
        -The throttle valve is shut (fully closed) <Except the driving condition that the fuel pressure exceeds the seizure resistance>
P1274             Supply pump protection                                          -Rail pressure is controlled in the range from 50 to 60 MPa.
        -When the burn-in limit is exceeded, the engine is stopped gradually.
P1275              Supply pump exchange                                           -Rail pressure is controlled in the range from 50 to 60 MPa.
        -The throttle valve is shut (fully closed) <Except the driving condition that the fuel pressure exceeds the seizure resistance>.
P1625             Injection quantity compensation value error           -Rail pressure is controlled in the range from 50 to 100 MPa.
P1626             Injection quantity compensation value not coding           -Rail pressure is controlled in the range from 50 to 100 MPa.
P2118             Throttle valve control (DC motor) current malfunction          -Power to the throttle valve control servo is interrupted.
P2122             Accelerator pedal position sensor (main) circuit low input       -The amount of depression of the accelerator pedal is detected
        with using the accelerator pedal position sensor (sub) signal,
        which is calculated by taking half of the normal value.
P2123             Accelerator pedal position sensor (main) circuit high input       -The amount of depression of the accelerator pedal is detected
P2124             Accelerator pedal position sensor (main) circuit high input intermittent         -The amount of depression of the accelerator pedal is detected
P2127              Accelerator pedal position sensor (sub) circuit low input                     -The amount of depression of the accelerator pedal is detected
        with using the accelerator pedal position sensor (main) signal,
P2128              Accelerator pedal position sensor (sub) circuit high input                      -The amount of depression of the accelerator pedal is detected
P2138            Accelerator pedal position sensor (main and sub) range/performance problem              -The accelerator pedal opening is controlled as 0 %.
P2146            Injector common 1 (cylinder No. 1and No. 4) circuit open                      -Exhaust gas recirculation control is stopped (fully closed).
P2147             Injector common circuit earth short                                                     -The engine is stopped (fuel injection and pump pressure feed are stopped).
P2148            Injector common circuit battery short                                                  -The engine is stopped (fuel injection and pump pressure feed are stopped).
P2149            Injector common 2 (cylinder No. 2 and No. 3) circuit open                    -Exhaust gas recirculation control is stopped (fully closed).
P2228            Barometric pressure sensor circuit low input                                        -Exhaust gas recirculation control is stopped (fully closed).
P2229           Barometric pressure sensor circuit high input                                       -Exhaust gas recirculation control is stopped (fully closed).
P2413            Exhaust gas recirculation system performance                                     -Exhaust gas recirculation control is stopped (fully closed).
visit_spg
กระทู้: 22
« ตอบ #4 เมื่อ: กันยายน 17, 2013, 01:04:49 pm »
มาช่วยป๋าโดมครับ code มันเยอะครับป๋า copy มาแปะทั้งหมดจะไหวหรือครับ แถมรายละเอียดแต่ละ code เยอะอีกต่างหาก ให้ link ไปเลยครับ ใครอยากทราบ code อะไร หรือ code อะไรโชว์ขึ้นมาก็ search เองได้เลยครับ
search ได้ตาม link นี้เลยครับ
http://engine-codes.com/
หรือจะในกระทู้ที่มีป๋าเคยเอามาลงไว้ในนี้ก็ได้ครับ
 http://www.pajerosport-thailand.com/forum/index.php?topic=18115.0
« แก้ไขครั้งสุดท้าย: กันยายน 17, 2013, 01:11:25 pm โดย visit_spg » บันทึกการเข้า
« ตอบ #5 เมื่อ: กันยายน 17, 2013, 01:07:58 pm »
พอดีผมมีเป็นคู่มือซ่อมบำรุงคับ อันนี้พิมพ์ไว้ให้ดูคร่าวๆ
visit_spg
กระทู้: 22
« ตอบ #6 เมื่อ: กันยายน 17, 2013, 01:10:31 pm »
อ๋อ....ครับป๋าโดม.......แล้วมันจะเหมือนกันหรือเปล่าครับป๋า ผมไม่เคยมีเจ้าคู่มือนี้เลย.....และถ้ามันมีภาษาไทยจะแจ่มมากเลยครับ เพราะบางทีอ่านภาษาอังกฤษ ก็เข้าใจยากเหมือนกัน เพราะมันเป็นศัพท์เฉพาะทางช่าง....ไม่ทราบว่าคู่มือที่ป๋าโดมมีพอจะมีแปลเป็นไทยมั๊ยครับ
« ตอบ #7 เมื่อ: กันยายน 17, 2013, 01:16:13 pm »
ไม่มีคับ มันใช้ร่วมกันทั่วโลกทั้ง ไทย ต่างประเทศคับ
« แก้ไขครั้งสุดท้าย: กันยายน 17, 2013, 05:32:51 pm โดย Adisak (โดม) » บันทึกการเข้า
paje_E20NYA
กระทู้: 277
« ตอบ #8 เมื่อ: กุมภาพันธ์ 26, 2015, 02:34:03 pm »
Code P2127 แสดง 3 รอบแล้วครับป๋า  ลบด้วยสมาร์ทการ์ดแล้ว..หาย..สามารถขับได้ปกติ(ชักเป็นบ่อยแล้ว..แจ้งศูนย์แก้ไขให้จะหายไปเลยไหม? อาการนี้) สาธุ (น่าจะปักหมุดนะครับ  หัวข้อนี้มีประโยชน์มาก)
« แก้ไขครั้งสุดท้าย: กุมภาพันธ์ 26, 2015, 02:36:39 pm โดย paje_E20NYA » บันทึกการเข้า
ID No. 0449  (PJS 2011 4X4  4WD 178 HP)
« ตอบ #9 เมื่อ: กุมภาพันธ์ 27, 2015, 05:52:51 am »
2127 เช็คปลั๊กคันเร่งครับ อาจจะมีหลุด/หลวมครับ
น่าจะมาพร้อม 2128 ด้วยครับ ถ้ามีกล่องคันเร่ง ลองใส่ปลั๊กิุดดูครับ
paje_E20NYA
กระทู้: 277
« ตอบ #10 เมื่อ: กุมภาพันธ์ 27, 2015, 09:38:00 am »
ถอดกล่องคันเร่งออก  ใส่ปลั๊กอุด  ..  ใช่ไหม? ครับ (จะทดลองดูครับป๋าเอก)  แล้ว P2127 และ P2128 ความหมายคืออะไรครับ  (ขอคำชี้แนะด้วยจร้าา) สาธุ สาธุ สาธุ  (อาการอย่างนี้กลัวจะเป็นในช่วงใช้ความเร็วและช่วงแซง แล้วเครื่องยนต์วูบ มีโอกาสเป็นได้ไหม? ครับป๋า)
« แก้ไขครั้งสุดท้าย: กุมภาพันธ์ 27, 2015, 09:41:15 am โดย paje_E20NYA » บันทึกการเข้า
ปาโลมา
กระทู้: 286
« ตอบ #11 เมื่อ: กุมภาพันธ์ 27, 2015, 01:15:54 pm »
มาป๋าเอกช่วยตอบครับ
ถ้าป๋าจขกทใช้กล่องคันเร่งแบบปลั๊กเสียบ (ํY socket)ให้ถอด Y ออก และเอาปลัีกเดิมเสียบเข้าที่ชุดคันเร่งของรถครับ
หากเป็นรุ่นที่ตัด/ต่อสายไฟคันเร่งให้ลองใช้ปลั๊กอุด (แต่ปัญหาอาจเกิดจากจุดตัด/ต่อสายไม่แน่นหนาก็ได้)
ตามที่ป๋าโดมลงไว้ P2127 และ P2128 เป็นปัญหาเกี่ยวกับสัญญาณคันเร่งชุดที่สอง
(ในรถที่ใช้คันเร่งไฟฟ้า ชุดคันเร่งจะสร้างสัญญาณการเหยียบมาสองชุดเพื่อความปลอดภัย
ECU จะเปรียบเทียบสองสัญญาณนี้ซึ่งจะต้องมีค่าสัมพันธ์กัน)
กรณีของป๋าคือสัญญาณคันเร่งชุดที่สองมีค่าต่ำเมื่อเทียบกับสัญญาณคันเร่งชุดแรกครับ (P2127)
paje_E20NYA
กระทู้: 277
« ตอบ #12 เมื่อ: กุมภาพันธ์ 28, 2015, 03:50:21 pm »
มาป๋าเอกช่วยตอบครับ
ขอบคุณครับป๋า และทุก ๆ ท่านมากครับ สาธุ สาธุ สาธุ
หน้านี้ถูกสร้างขึ้นภายในเวลา 0.067 วินาที กับ 20 คำสั่ง
