ผู้เขียน หัวข้อ: ของเล่นใหม่น้องปา OBD 2 OBD II Diagnose V1.4 Bluetooth Diagnostic Interface  (อ่าน 9733 ครั้ง)
« เมื่อ: มีนาคม 07, 2012, 09:19:32 am »
มากับราคา 20$ ฟรีค่าส่ง  แบบใช้สาย usb ราคา 15$ ใครสนใจไปหาจับจองเอากันครับ
ELM327 OBD2 OBDII V1.4 Bluetooth Diagnostic Interface
Article-Nr.:2530000
Product Details:
Condition: new
ELM327 Bluetooth CAN-BUS scan tool supports OBD-II protocols. It is used to read & diagnose trouble codes, clear trouble codes and detect fuel pressure and so on.
Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
Clear trouble codes and turn off the MIL ("Check Engine" light).
Display current sensor data, including:
Engine RPM
Calculated Load Value
Coolant Temperature
Fuel System Status
Vehicle Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen sensor voltages/associated short term fuel trims
Fuel System status
Fuel Pressure
Specifications:
Support OBD-II protocols as follows:
ISO15765-4 (CAN)
ISO14230-4 (KWP2000)
ISO9141-2
J1850 VPW
J1850 PWM
Item Size: approx. 8.7x4.5x2.5cm/ 3.42x1.77x0.98 inch
Compatible With?
Vehicle Coverage:
    BMW(1996~2005)BMW3,BMW5,X5,Z3,Z4,Z8,740i,750i,BMW Mini,E60,745i,745Li,765Li.
    Chrysler(1996~2008)
    Daewoo-Lanos,Daewoo-Leganza,Daewoo-Nubira
    FORD(1996~2008)
    GM(1996~2008)
    GEO prism, Honda/Acura,Hyundai,Isuzu,Jaguar
    kia,land Rover,Mazda,Mazda-Ford,Ford
    Merceds,Mitsubis
    Nissan,PROSCHE
    Subaru,Suzuki,Volvo,Rolls Royce 4,etc
    Multi-Protocol Support:
    SAE J1850 PWM(41.6Kbaud)
    SAE J1850 VPW(10.4Kbaud)
    ISO9141-2(5 baud init,10.4Kbaud)
    ISO14230-4 KWP(5 baud init,10.4 Kbaud)
    ISO14230-4 KWP(fast init,10.4 Kbaud)
    ISO15765-4 CAN(11bit ID,500 Kbaud)
    ISO15765-4 CAN(29bit ID,500 Kbaud)
    ISO15765-4 CAN(11bit ID,250 Kbaud)
    ISO15765-4 CAN(29bit ID,250 Kbaud)
    A.SAE J1939 CAN(29bit ID,250*Kbaud)
    B.USER1 CAN(11*bit ID,125*Kbaud)
    C.USER2 CAN(11*bit ID,50*kbaud)
« ตอบ #1 เมื่อ: มีนาคม 07, 2012, 09:21:56 am »
มันจะไปแสดงผลที่ใหนครับ
แต่น่าสนตัว usb  Cheesy Cheesy
ชายอิสระ
n
like: 72
กระทู้: 1884
« ตอบ #2 เมื่อ: มีนาคม 07, 2012, 09:52:12 am »
มันคืออะไรครับ  ใช่ทำอะไรได้บ้าง ช่วยอธิบายรายละเอียดหน่อยครับ
ภาษา E ไม่แข็งแรง...
« ตอบ #3 เมื่อ: มีนาคม 07, 2012, 10:00:58 am »
ขออภัยด้วยป๋าๆๆที่รักทั้งหลาย มันก้อเหมือนเจ้าตัว Smart Gauge นั่นแหล่ะ แต่ตัวนี้เอาไว้ต่อกับโน๊ตบุ๊ก ใช้งานร่วมกับโปรแกรมพวก Scan tools
ตัวอย่างใช้งาน
« แก้ไขครั้งสุดท้าย: มีนาคม 07, 2012, 10:04:26 am โดย auddyza » บันทึกการเข้า
« ตอบ #4 เมื่อ: มีนาคม 07, 2012, 10:06:11 am »
เคยใช้ครับไม่ดีเลย เสียตังเปล่าๆ หรืออาจจะเป็นที่ผมสั่งราคาแบบถูกๆเลยไม่ดี Huh? Huh? Huh?
« ตอบ #5 เมื่อ: มีนาคม 07, 2012, 10:13:48 am »
ผมเห็นมันถูกดีไงป๋า เลยหาเหยื่อให้ลองสั่ง ไม่ดีก้อคงไม่เอา ขอบคุณสำหรับคำแนะนำมากเลยป๋า
แต่สำหรับผมไงก้อติดเจ้า SmartGauge อยู่แล้ว เลยเจ้าตัวนี้ไม่จำเป็น แค่เอามายั่วต่อมน้ำลายป๋าๆๆ เผื่อมีใครสนใจ  Cheesy
naruto
Title - ID : 889
กระทู้: 504
Title - ID : 889
title107@hotmail.com
« ตอบ #6 เมื่อ: มีนาคม 07, 2012, 06:19:19 pm »
ผมเห็นขายอยู่ชุดละ 800 บาท พร้อมโปรแกรม  ว่าจะลองซื้อมาเล่นซะหน่อย  ต้องหาข้อมูลก่อนแระ
แต่คงต้องเสียบต่อ Notebook แล้วการแสดงผลหรือไม่ก็ต่อเข้ากับจอของรถเลย
Mayurin
like: 78
กระทู้: 1695
« ตอบ #7 เมื่อ: มีนาคม 07, 2012, 07:10:20 pm »
  เคยใช้อยู่ กับโปรแกรม ทอร์ค บนแอนดรอย ใช้ได้ดีพอควร ตัวสีฟ้าจะงานดีกว่าราคาพอกัน
 ดูตัวอย่างการใช้งาน http://www.thaigoodpost.com/articles/automotive/303
« แก้ไขครั้งสุดท้าย: มีนาคม 07, 2012, 07:12:45 pm โดย O Naklua No.126 » บันทึกการเข้า
« ตอบ #8 เมื่อ: มีนาคม 07, 2012, 10:59:33 pm »
ตอนแรกก็สนตัวนี้อยู่เหมือนกันครับ แต่ดูแล้วน่าจะยุ่งยากในการใฃ้งานอยู่เหมือนกัน เพราะต้องมาคอยเปิดโปรแกรมจากมือถือทุกครั้งที่ต้องการใช้งาน ก็เลยจัด monster guage มาแทน แพงกว่าอีกสี่เท่าตัวแต่สะดวกในการใช้งานมากกว่า ตอนนี้หลักๆเอามาดูอัตราการใช้น้ำมันอย่างเดียว ใช้อ่านค่านี้มาได้อาทิตย์นึงแล้วครับ พอจะจับทางลักษณะการกินน้ำมันของเจ้าปาอ้วนได้แล้วว่าขับยังไงจะ save น้ำมันได้มากขึ้น เีดี่ยวให้ลองซัก 2 ถังก่อนถ้าเป็นไปอย่างที่คิดไว้จะมาเล่าให้ป๋าๆฟังครับ
ปลากรอบ(GOFF)
กระทู้: 411
« ตอบ #9 เมื่อ: มีนาคม 08, 2012, 01:22:33 pm »
  ไม่ดียังไงบ้างครับป๋า  พอดีสนใจอยู่ เห็นป๋า auddyza สั่งได้ถูกดี  แต่ความจริงอยากได้แบบ For iPAD2  อยากถามป๋า auddyza ว่าราคาเท่าไหร่  ขอบคุณล่วงหน้าครับ
suksanhunsa no.917
YNWA
กระทู้: 55
« ตอบ #10 เมื่อ: มีนาคม 08, 2012, 02:23:32 pm »
อยากได้แบบ bluetooth มาต่อใช้กับ android เหมือนกันครับ สั่งถูก ๆ ได้ที่ใหนครับ
Patum370
กระทู้: 448
« ตอบ #11 เมื่อ: มีนาคม 08, 2012, 07:30:20 pm »
ผมซื้อที่นี่ครับ ร้านอยู่ศรีราชา 800 บาท มีซอฟท์แวร์แถมด้วยครับ www.tools111.com แต่ผมใช้แล้ว มันไม่เห็นออกซิเจนเซนเซอร์ แต่อย่างอื่นก็เชคได้หลายตัวอยู่ครับ ลบ แอเรอร์โค๊ดก็ได้ด้วย
ขับช้าลง ใจเย็นขึ้นเยอะ
Patum370
กระทู้: 448
« ตอบ #12 เมื่อ: มีนาคม 08, 2012, 07:54:12 pm »
http://www.thaiobd.com/elm_product.html  ที่นี่ก็มีครับแต่แพงกว่านิดนึง ดูเอาครับ มีไว้Checkแบบขำๆ ถ้าตัวจริงแบบศูนย์เป็นแสนล่ะครับ
« ตอบ #13 เมื่อ: มีนาคม 08, 2012, 11:01:14 pm »
ป๋าอู๊ด  ลองไปดูกระทู้นี้ครับ   มีทั้งคำตอบและการทดลอง  หลายแบบเลย
http://www.pajerosport-thailand.com/forum/index.php?topic=268.0
